Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 19, 2005
Old     (mnwakerider)      Join Date: Jun 2004       06-01-2005, 12:45 PM Reply
I have a couple smaller dings that i would like to keep smaller... How do i seal them up or fix them? I dont want the water to erode the dings into anything larger...
thanks for the help, jb
Old    drewsky24            06-01-2005, 12:55 PM Reply
Epoxy.
Old     (hamkj)      Join Date: Apr 2002       06-01-2005, 1:51 PM Reply
Everyone will say epoxy or fibre glass compound... The absolute best thing in my opinion!!!
JB WELD. I had a friend with a brand new board... fell off the rack... and got stuck in the cleat... so you can imagine the 6 inch long 3 inch deep chunk out of the side of the board...
I picked away at the foam and fragments and then filled with multiple layers of JB WELD... then sanded it... it is stronger than the original!!!
Old     (wakeworld)      Join Date: Jan 1997       06-01-2005, 2:21 PM Reply
http://www.wakeworld.com/articles/2004/fixadent.asp
Old     (mnwakerider)      Join Date: Jun 2004       06-01-2005, 11:30 PM Reply
Kyle - whats the JB WELD? where can i pick some up? I like the way it sounds so far. And thanks for the link David.
Hope it all works out!
jb
Old     (ladythump)      Join Date: Jul 2004       06-02-2005, 6:58 AM Reply
John,
West Marine sells epoxy in handy single serving packets. It works great for things like this. At the end of the snowboarding season, I use it to fix all the new dings in my snowboard.
Old     (hamkj)      Join Date: Apr 2002       06-02-2005, 8:45 AM Reply
JB WELD can be bought at a hardware store or walmart or automotive parts place. this stuff is like liquid metal... once it drys... it can be sanded... but not much will be able to break it... i find other epoxies change when exposed to heat, sun, water etc.... JB WELD is used to glue together minor cracks in engine blocks... that should tell you how strong it is!
Old     (socalwakepunk)      Join Date: Dec 2002       06-02-2005, 9:05 AM Reply
JMO - small dings, chips, whatever do not = broken board. When it is in 2 or more pieces, then it is broken. Otherwise, no repair is necessary.
Old     (big_ed_x2)      Join Date: Jul 2004       06-02-2005, 9:23 AM Reply
I agree Jeff.
How long do you ride your old board anyways?What 2,3 maybe 4 years and you get a new one.
No repair is necessary.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-02-2005, 11:18 AM Reply
i agree, whats a small ding? it gives the board character and its not going to keep you from sticking your new move. But, if its deep enough, can't water seep into the core of the board and really screw it up?
Old     (socalwakepunk)      Join Date: Dec 2002       06-02-2005, 11:25 AM Reply
Closed cell foam - no. I have a HL DNA core Belmont that has a big chunk missing from the bottom (slider mishap). Been riding it like that for years.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-02-2005, 12:23 PM Reply
awesome - now i don't have to fix that gash in the bottom of my deck from the side of a wetbox!
Old     (hamkj)      Join Date: Apr 2002       06-02-2005, 2:22 PM Reply
One other thing when I used JB WELD... I spread the JB WELD over the "edge ding" and then use a strip of clear packing tape and wrap it so it takes the shape of the edge... when it dries after 24 hours, you peel the tape off and the JB WELD peels off from the smooth parts of the board leaving only JB WELD in the damaged area... works like a dream...
