Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 21, 2007
Old     (wanabe)      Join Date: Nov 2006       02-16-2007, 5:41 PM Reply
could someone tell me what it means to load the line?
Old    meyerb            02-16-2007, 5:49 PM Reply
oh man!
Old     (wanabe)      Join Date: Nov 2006       02-16-2007, 5:55 PM Reply
Is that your final answer? Thanks for the help!
Old     (closedtoe)      Join Date: Jan 2007       02-16-2007, 5:57 PM Reply
When you cut into the wake hard you get line tension. When you launch off the wake you get the spring from the line having all of that tension.
Old     (stephan)      Join Date: Nov 2002       02-16-2007, 6:39 PM Reply
It refers to using the proper Progressive Edge technique. When done correctly you will have your strongest edge as you leave the wake and will have effectively "loaded the line". Do a search for Progressive Edge and you will find an extensive description on how to do it correctly. Learn that and the possibilties of wakeboarding will open up in front of you.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       02-16-2007, 6:53 PM Reply
its about building energy man. and then transferring it thru your board. you gotta fly like an eagle, Marc. you got this. you seen any dv's yet man? like detention, waketrix,the book? good stuff.
