On my Lexus marine engine, I pull the plugs, blast a 2 second burst down into the 4 valve hemispherical combustion chamber, then replace the plug. I do this for all 8 cylinders, then turn the engine over for a coupla seconds with the ignition kill switch removed. Your engine would be the same, minus the hemi heads and four valves
You can't spray fogging oil into an MPI system, it doesn't have any kind of throttle body. This is actually the best way to do it, it gets right into the cylinders without going through the fuel system. Hope that was quick enough!
