Then you have to buy two hole saws. They seem to run close to $50 each at that size. I think it would be great if we had a loaner that would pass from wakeworlder to wakeworlder for a small fee. I ended up using the rotozip and that worked pretty well. Much better after I broke a bit and got a new one. Make sure to use a sharp bit. Wetsounds is genius, you will never be able to use another 6.5 inch speaker in there again, once the hole is too large, unless you like fiberglass work.
