Old     (ord27)      Join Date: Oct 2005       03-27-2018, 1:40 PM Reply
I have an extra head unit that I am going to use in my garage. I've purchased a transformer that converts the house 120 to 12 volts.
I hooked it up to 2 speakers and it works great
I also want to be able to toggle between using the Kenwood unit and an old car 8 track player that I have.
I'm thinking about running speakers that are specific to each unit, but I want them to share the power source.
I'm thinking that I can use a 3 way toggle, but the toggles that I have found don't offer an ability to attach power and ground from the source (transformer). Am I missing something obvious?
anyone recommend a switch that will work?
on 1: provides power to Kenwood.....
off
on 2 provides power to 8 track player
Old     (bcrider)      Join Date: Apr 2006       03-27-2018, 2:10 PM Reply
Am I missing something obvious? -Besides the fact that all can be covered by a bluetooth speaker and a cell phone? lol. Sorry, had too.
A 3 way rocker should work, no? similar to the way a rocker switch is used to fill/empty ballast with an aerator set up anyway. They share a common ground, Main power from source and individual source power on each end of the rocker.
https://www.amazon.com/X-Haibei-Wate...7894D3DGS2RQD7
Old     (ord27)      Join Date: Oct 2005       03-27-2018, 2:49 PM Reply
thanks
the ones that I saw , didn't have the ground
Old     (fly135)      Join Date: Jun 2004       03-27-2018, 6:49 PM Reply
Attach the ground to both units and toggle the power to each.
Old     (fly135)      Join Date: Jun 2004       03-27-2018, 6:51 PM Reply
You are wanting a DPDT switch. But a DPST will work since only power needs switching.
Old     (fly135)      Join Date: Jun 2004       03-28-2018, 5:43 AM Reply
Correction "SPDT". Single Pole Dual Throw.
Old     (ord27)      Join Date: Oct 2005       03-28-2018, 7:23 AM Reply
thanks guys! I'm restoring a 1970 Superbee. I've got an original AM 8 track player to put in it. The 8 tracks are available, but do require rebuilding. It will be nice to be able to test them from the work bench.
