08-05-2016, 2:43 PM
Anyone have any photos or attempted to mount them onto the S-Bend?
08-06-2016, 11:18 AM
Nope I've got 6 Exiles if you want photos .
08-06-2016, 3:40 PM
My friend has a pair of Rev 410's on his Mojo with the S-bend tower.
08-06-2016, 8:27 PM
Dusty, what about a single 410 with a pair of Rev10's? That way the Rev10's wouldn't be affected too bad with being off-axis?
08-06-2016, 8:30 PM
The Supra tower just won't let one mount in the middle due to the cross piece. It's no longer just a tube but flat.
The off axis look would end up driving me insane, and there are a few differences in the moomba s and supra s that I'm not even sure they would mount.
08-07-2016, 1:27 AM
I haven't had any newer Supra's in my shop yet, and haven't seen any at the lake. You may be better off sticking with the Rev10's.
09-08-2016, 1:15 PM
Just an update, Tim and Odin helped me make this happen. Tim got an empty pod in my hands so I could take measurements and have custom brackets machined. I know have 2 410s on the tower powered by an sd4
09-08-2016, 1:17 PM
09-08-2016, 1:20 PM
Meh ....
09-08-2016, 1:52 PM
Dusty,
WOW! That is so impressive that you were able to level the speakers on a radiused tower.
And, I'm a big fan of tower speakers that are on the same depth plane.
09-08-2016, 2:44 PM
Thanks David.
09-08-2016, 6:34 PM
As long as you are happy that's all that matters. Not for me though.
09-11-2016, 7:15 AM
Looks great!
09-11-2016, 5:13 PM
Dumped exile huh?
09-11-2016, 8:05 PM
Made the switch, yessir.
09-12-2016, 7:16 AM
Dusty,
Any close-up pics on the design/millwork of the custom tower speaker mounts?
Have you copied the mounts to Wetsounds?
09-12-2016, 12:43 PM
Nice Install........
Pics of the Amp Rack???
Still cant believe you switched!!!!!
09-12-2016, 1:27 PM
I did the same thing I went with on Kg's Mojo. This is a pic of his, but I did mine identical.
From left to right:
Sd2 - powering 12w7
Sd4 - powering 410s
Sd6 - powering in boats
4 zones of rgb lighting in the boat, (1) Floor, (2) Mid level, (3) speaker rings and tweeters, (4) tower and exterior accents. Each is independently controllable or can be synced together as 1 zone. All share the same remote. All factory integrated, no additional switches or magic combos of buttons to try and explain to someone. Everything is ran thru the vision system with the redundant factory switches
09-13-2016, 8:52 AM
Looks good brother
09-14-2016, 5:09 AM
From left to right:
Sd2 - powering 12w7
Sd4 - powering 410s
Sick...... Welcome back from the Dark side!!
01-11-2021, 2:49 PM
This might be a long shot. But I’d like to do 2 410s on my Supra with S bend.
Any way I could get a set of the clamps where you purchased them from?
