Old     (Lemonade)      Join Date: May 2015       05-11-2016, 7:47 AM Reply
Does anyone have any pics of how their towers are wired. I'm seriously contemplating tower speakers but want to know whats involved in the install.
Thanks,
Old     (bcrider)      Join Date: Apr 2006       05-11-2016, 9:03 AM Reply
What's involved is mostly time and patients and a spare pair of hands. You can use a multi bit/step down bit to make your holes. You'll need a fish tape to run up/down the tubes. I'd pull a string in first as well, then the wires. The other trick that can work is to use a really light string like dental floss and a vacuum. We do this for blowing conduits that are too long for a fish tape...obviously not with dental floss. You at the opposite end you need a piece of coat hanger or such with a hook on it to try and pull the string through. Rubber grommets at the holes will help the wire not to chafe. Depending if you need to fold your tower you will need disconnects to go through the hull.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-11-2016, 9:32 AM Reply
Run the wires through where the tower hinges to fold and you won't have to disconnect
Agree with all the above. Wired my last one, wasn't fun but wasn't terrible either.
Old     (Lemonade)      Join Date: May 2015       05-11-2016, 9:47 AM Reply
Whick of the top cross members would you mount the speakers on? Forward or aft?
Old     (jonblarc7)      Join Date: Jul 2006       05-11-2016, 10:28 AM Reply
aft
