Old     (Max16)      Join Date: Aug 2015       09-02-2015, 7:37 AM Reply
This is my 1st post so hello guys !
I have a 2009 230 and nothing really is "bolt on" to this boat. To install the oem NSS you have to move the platform mounts and do some fiber/gelcoat.
I decided to design my own plates and have them laser cut. My design is made to install on 230 with a lower platform.
I used the same lenco as Nautique do and my control is the lenco switch with auto-retract feature.
There goes for the pictures.
There goes the video. It was done with only hard tanks filled to test the setup.
https://www.youtube.com/watch?v=bTe_AlM6rZk
Old     (King12)      Join Date: Jul 2012       09-02-2015, 8:00 AM Reply
NICE JOB! That's a freaking sweet looking set up!!!! I want more wake pics and videos! More weight, different arrangements etc helluva first post my friend!
Old     (zimme)      Join Date: Feb 2013       09-02-2015, 11:17 AM Reply
That's sweet. Does NSS deploy on non surf side like all the other surf systems? So the port side would deploy to surf starboard, and vice versa?
Old     (Max16)      Join Date: Aug 2015       09-02-2015, 11:25 AM Reply
I did not take more pictures! I was too excited to ride the setup and we were having too much fun hahaha
We did run with full weight. I have a total of 2200 lbs in the back and 1200lbs in bow. The wave is huge!!
I run easily 20ft behind the boat on a 4'8" board and I'm 205lbs.
Same thing as other surf system, NSS deploy on the "non-surf" side
When switching side the steering turns 1/4 turn !
Old     (lifetimewarranty)      Join Date: Oct 2008       09-02-2015, 11:35 AM Reply
Great job!!!!!!!!!
Old     (jonblarc7)      Join Date: Jul 2006       09-02-2015, 12:39 PM Reply
Have to agree that's a hell of a first post!!!!!!!
Old     (Max16)      Join Date: Aug 2015       09-02-2015, 6:42 PM Reply
Thanks!
Old     (North_LA_Hunter)      Join Date: Aug 2015       09-02-2015, 7:25 PM Reply
Just thinking here...
What if you broke it on a 45* out towards the wake and maybe you could go further out with it and maybe give you a better wake without the extra stress on the back of your transom.
Old     (Pad1Tai)      Join Date: Jan 2013       09-02-2015, 7:39 PM Reply
Nice job man.... Whats the part number on those Lenco Actuators... They look shorter than 10 inches when retracted.. Thanks..
Old     (Preston)      Join Date: Jul 2010       09-02-2015, 7:43 PM Reply
Dang! Awesome job.
Old     (Max16)      Join Date: Aug 2015       09-02-2015, 7:46 PM Reply
I calculated the force on my transom before going ahead. Water pressure at 15mph is 3,25psi following fluid density and speed formula.
My plate extend the boat by 2,25in which turns to 100 sq.in. So in total my plate supports around 300 lbs at 15mph.
I surf around 10-11 so the plate get less than 300lbs.
I have 8 bolts supporting my system but 5 of them are on the critical edges. If there was only these 5 bolts, they would take 60 lbs each which is pretty low. The transom is around 3\4 thick so it's capable of supporting this.
Lenco's are the 101-XDS which are 10in retracted length.
Old     (North_LA_Hunter)      Join Date: Aug 2015       09-02-2015, 8:01 PM Reply
Okay. I was just curious if you could go further out with them and get a better wake. Of if It would kill it.
Old     (King12)      Join Date: Jul 2012       09-02-2015, 9:33 PM Reply
How's it act on a bit of a list? Like 7 degrees or so?
Old     (Max16)      Join Date: Aug 2015       09-03-2015, 6:10 AM Reply
@Brandon, I have no idea. The further you go the more risk you have of bending the plate. Right now it only extends 2 1/4 which is the same as the original NSS.
@Joel, not sure I understand your question??
Old     (King12)      Join Date: Jul 2012       09-03-2015, 7:10 AM Reply
Both of the instances you talk about were evenly weighted, have you tried listing slightly while deploying the gate? What does that do to the wave? Wondering since I've heard of people with gates having an equal sized/bigger/different wave listed slightly with gate while saving fuel compared to 100%slammed evenly/unlisted.
Old     (King12)      Join Date: Jul 2012       09-03-2015, 7:11 AM Reply
Also lets have that video fully slammed!
Old     (Max16)      Join Date: Aug 2015       09-03-2015, 7:17 AM Reply
OK! Yeah I tried several setup that day.
Super ideal for the biggest/cleanest wave is full ballast on surf side, 3/4 full on non-surf side and always 3/4 of people in boat on surf side with NSS deployed full on non-surf side. This way the wave is a competition one !!
Depending how you want the wave (long or super steep), I move people in the bow.
As for fuel, it just depends on what type of wave you want. Riding a long wave I run 2700rpm and when we ride a steep wave i'm at 3000-3100rpm to keep around 11mph. I have a 1235 prop, just depends on what angle the boat is at.
Old     (grant_west)      Join Date: Jun 2005       09-03-2015, 8:18 AM Reply
Do you have any photos or info on the studs that anchor into your transom.
Great Job!
Old     (Max16)      Join Date: Aug 2015       09-03-2015, 8:22 AM Reply
Similar to these, in stainless.
Old     (King12)      Join Date: Jul 2012       09-03-2015, 9:33 AM Reply
Ya Ima need some pics of that wave How about pics of the switches at the helm
Old     (Max16)      Join Date: Aug 2015       09-07-2015, 6:09 AM Reply
For those who wanted to see. Here is the wave with full ballast on port , 3/4 starboard and belly+arrow in the front. Only 3 in the boat.
https://youtu.be/QGvbsLunCgk
Sorry there was some traffic so the other waves hits mine but you can see what it gives
