Old     (conrmic)      Join Date: Jan 2015       05-17-2015, 6:08 AM Reply
I have a 2004 Tigé. It's like a ski/ wakeboard boat so the wake is about half the size of a real wakeboard boat. I have added 3 fat sacs to weight it down. Anybody have any other ideas of how to get the wake bigger? Any help would be appreciated. Thank you
Old     (boardman74)      Join Date: Jul 2012       05-17-2015, 7:44 AM Reply
It would help to know what model it is. Also DD or Vdrive as that effects the weight bias.
Old     (FastR3DN3K)      Join Date: Jun 2013 Location: Midlothian TX       05-17-2015, 9:11 AM Reply
What model? Does it have the TAPS plate? What size bags are you currently running? Can't really help you if we don't know your current setup.
Old     (boardman74)      Join Date: Jul 2012       05-17-2015, 9:55 AM Reply
2004 will have TAPS. Anything Tige after 1996(may be 1995).
Old     (conrmic)      Join Date: Jan 2015       05-17-2015, 10:07 AM Reply
Yes sorry it does have TAPS and it is a Tigé Switch V
Old     (boardman74)      Join Date: Jul 2012       05-17-2015, 10:20 AM Reply
Switch V is the same as a 20V. That boat likes a pretty even distribution of weight front to rear. If you over weight it the wake will start to roll over. It can also be sensitive side to side. I would grab a set of the 400 lb Vdrive sacs and put one in each side rear locker. Then about 600 in the from in either a regular bag or a U-shaped sac under the seats. Use your Taps as little as possible to clean the wake. The more you use it the more it lifts the stern of the boat and reduces the wake. I'd say start around TAPS 5-6.
