Old     (RanchDweller)      Join Date: Jun 2010       05-19-2014, 2:11 PM Reply
I have a 2013 Axis A22. The previous owner shipped the boat with the Z5 canvas off. Does anyone know how to reinstall the canvas? I have figured out how the canvas sits on the frame. I can't figure out how to re-string the rope with the ratchet hooks. I called Z5 and they can only tell me that they are shipped installed and can't help. Thanks for any info or pics.
Old     (BGeorge01)      Join Date: May 2014       05-19-2014, 2:19 PM Reply
Man that's crappy of Z5 to not help you out!
Old     (chattwake)      Join Date: Jan 2010       05-19-2014, 2:26 PM Reply
Here's what it looks like with the cover on. Basically, the string runs on the inside of all of the loops in the canvas after it wraps around the outer bars, and then loops over the little screwed in black tabs. The tensioners sit under where the pockets Velcro back to the underside of the canvas on each side of the rack. you can get it all set up without them being tight. Then just run the string through the tensioners and pull tight. the hardest part is simply routing the top back how it needs to sit on the frame.
Hey, get it powder coated while its apart. it looks great if it matches your tower.
Old     (chattwake)      Join Date: Jan 2010       05-19-2014, 2:30 PM Reply
Old     (iShredSAN)      Join Date: Apr 2012       05-19-2014, 2:38 PM Reply
pretty sad that a company can charge a couple grand for a bimini but doesn't feel the need to help a current owner out. I mean how hard would it be for them to at least send you some pics or a spec sheet... I could understand if this was a cheap sun shade but for that kind of cash I would expect some decent customer service
Old     (chattwake)      Join Date: Jan 2010       05-19-2014, 2:43 PM Reply
Who did you talk to over there? I've always dealt with Ray Jesewitz and he's be absolutely incredible. Here's his email: ray@jesewitz.com
Maybe he can help put you or put you in touch with who you need to speak to.
Old     (you_da_man)      Join Date: Sep 2009       05-19-2014, 2:45 PM Reply
Yup, $2500 when you order with new boat build, $3500 after
Old     (you_da_man)      Join Date: Sep 2009       05-19-2014, 2:46 PM Reply
I wish I was home to take detailed pics for you on my Axis but I just got to the oil rig today...obviously I'm busy lol
Old     (ajf4242)      Join Date: Aug 2008       05-19-2014, 2:47 PM Reply
It's actually pretty easy once you do it once. . . I took some pictures with my phone of how it was before I took the canvas off. I don't know how easy it will be just looking at pictures. . . but I will try to figure out how to get them off my phone and on to here to help out.
Old     (ajf4242)      Join Date: Aug 2008       05-19-2014, 4:29 PM Reply
Here is the photos I have of it. . . hope it helps. Like Chatt said, Ray is great to work with and has taken care of me with some issues I had.
Old     (RanchDweller)      Join Date: Jun 2010       05-20-2014, 7:18 AM Reply
Andrew / Chattwake-
You guys are awesome. Thanks for the detailed pictures. That is exactly what I needed. It only took 1 beer with those pictures. I do like the white power coat look. Thanks guys!
Old     (Pad1Tai)      Join Date: Jan 2013       05-20-2014, 7:21 AM Reply
Best Bimini I ever owned........... My problem was figuring out the configuration of the 5 piece string setup.. so none of the unions showed..
