Old     (tims72)      Join Date: Apr 2008       05-23-2013, 5:50 PM Reply
Trying to find a dealer from Santa Rosa to Los Angeles dealer to Bakersfield that has a XXX in stock. Mine just blew don't know if it was the amp caused it or what but 1 min into our trip smoke was coming out by my feet. I have 2 other 12'sthat aren't working anymore either. Thanks for the help
Old     (wetsounds1)      Join Date: Jan 2006       05-23-2013, 6:56 PM Reply
Give us a call at 877-938-7757. We can find a dealer near you. The XS-XXX is a spl woofer that takes a big box and a lot of power. So not a woofer dealers normally keep in stock. Usually order them in for big systems.
We can also re cone yours and get it rocking again. I know, not in time for the weekend. It sounds like there could be some other issues going on though so your amps and settings and entire system needs to be looked over so not to repeat the issue.
Tim
Wet Sounds
Old     (DEMENTEch)      Join Date: Jun 2013       06-23-2013, 9:48 AM Reply
Tim
Wet Sounds
Is there a big difference between the XS-12 and the XS-XXX ???.....
Old     (david_e_m)      Join Date: Jul 2008       06-23-2013, 10:17 AM Reply
Sure. There's a big difference depending on the application. But you shouldn't select a woofer in isolation.
With a lower powered amplifier the XS-12 would actually have an advantage.
The XXX-12 will play much louder IF you have the additional power so not only is the extra power justified, it becomes essential.
The difference between the output of two woofers of equal size is the excursion. More excursion is the only way the same woofer can displace more air. If one woofer has to move the cone twice the distance and still under control this is major challenge and requires a very different type of build and demand for power.
You have to reconcile the woofer with your particular set of expectations & boat, and balance it with your specific system.
David
Earmark Marine
Old     (WakeDirt)      Join Date: Jun 2011       06-23-2013, 8:23 PM Reply
So what amp is best for the XS12? Syn 2?
Old     (jonyb)      Join Date: Nov 2008       06-24-2013, 7:58 AM Reply
Syn2 or HT1 would work.
Old     (slipknot)      Join Date: Aug 2001       06-24-2013, 9:59 AM Reply
now that right there is some fine customer service Tim!
