Old     (phall925)      Join Date: Feb 2005       05-06-2013, 8:57 AM Reply
Guy I have an 08 VLX and on the rear compartments the screws that hold the gas shock mounts in place to the hatch have pulled out of their original hole. In other words the hole has been stripped out. Any ideas on possible fix.
Thanks
Old     (edgeski1)      Join Date: Jan 2013 Location: Portage, Mi       05-06-2013, 9:18 AM Reply
make a plate out of metal, 3"x3" drill holes in all sides, you can probably fit three holes per side. Mount that to the trunks, mount the gas shock mount to that. We've done this, and seems to hold better
Old     (austin)      Join Date: Apr 2010       05-06-2013, 9:22 AM Reply
There are some threads about that kind of thing on the bucrew forums. Some guys have welded larger base plates to the mounts to distribute the load better. For a quick fix you can either move the mounts slightly to make new screw holes or put larger screws into the old holes.
Old     (Dmac420sj)      Join Date: Mar 2012       05-06-2013, 9:23 AM Reply
^^good idea. I put 2 1' pieces of solid birch resined and then mounted to that, this way the tension is distributed over a bigger area.
