Did you read the product description? Its not mind blowing. One has a grind base, one does not. Get the grind base if you plan on riding cable. Otherwise, save yourself the weight and get the regular base.
Yupper. Grind will have a more durable base if you're going to be beating it up a bit. Not a ton of difference. Rails and cable, get the grind base. Boat, get the standard.
