Old     (Down2Ride)      Join Date: Aug 2011       08-25-2011, 1:39 PM Reply
I have a 2001 Supra Launch DD. The Rule 2000 pump for the ballast just quit working. The pump come on and I can feel air when the fill hose is disconnected. I can rotate the pump clockwise and counter-clockwise. Could it be an air pocket. Just not pumping the water. I can see what looks like a small leak under the base of the pump. Do I just need to tighten it to the hull to seal it better? Seems like it is a PIA to change these pumps out. The pump comes on, just doesn't pump water. Any help? I'm new to wake boats and bought this one as a fix-up although everything worked when I bought it. Just needed some TLC. The pump worked one day and not the next.
Old     (silvtondvl)      Join Date: Dec 2002       08-25-2011, 3:25 PM Reply
Did you try driving the boat forward while the pump was on? Most pumps will prime that way.
Old     (Down2Ride)      Join Date: Aug 2011       08-25-2011, 5:04 PM Reply
Haven't tried that, don't think. Not sure. I'll give it a shot Sat. Thanks.
