Old     (brycejb328)      Join Date: Aug 2009       08-24-2011, 4:18 PM Reply
Yo,
I might be working a deal with a guy on a 2004 centurion avalanche "storm II series"
Can anyone tell me what "storm II" means on this boat (ballast package, options??)
Everything I find about the boat is older threads, and wanna know any current info on how the wake is? I know the seller said it does have factory ballast, but he was rather un-sure on how much.
This does have the walk through transon.. any thoughts on that??
Checking with seller if it has trim tab (if its electric or manual) or the switch blade.
ANY info about this boat would be greatly appreciated.
Old     (polarbill)      Join Date: Jun 2003       08-24-2011, 4:22 PM Reply
I think it means it has front and rear ballast, tower, PP, graphics, board racks and maybe a coupel other things.
That is before the switchblade. Also, storm 2 may have come with a trim tab but then again it could be part of storm 3.
Old     (brycejb328)      Join Date: Aug 2009       08-24-2011, 4:25 PM Reply
^^sadly, the seller said the boat doesnt have perfect pass. Maybe storm III is perfect pass? I know nothing about centurion!
Old     (polarbill)      Join Date: Jun 2003       08-24-2011, 4:36 PM Reply
Just found what is in each package.
Storm 1
Tower, Center Ballast, Storm Gelcoat, Batwing Storm Decals
Storm 2
Dual Rear Ballast, Custom Stereo System, 2 Centurion Board Racks, 2nd Battery w/ Isolator
Storm 3
Bennett Trim Tab and Perfect Pass Wakeboard Pro
Old     (gnarslayer)      Join Date: Sep 2008       08-24-2011, 4:44 PM Reply
the avalanches throw monster wakes stock i love them
Old     (brycejb328)      Join Date: Aug 2009       08-25-2011, 5:35 AM Reply
^^ sounds like you've rode one!! i've heard some mixed reviews, sounds like you definantly need to compensate for prop rotation on this boat more than normal with extra ballast?? I fear getting a boat that is washy at 85 feet, not that I ride that far back... but some people i ride with do!!
Old     (jeff_mn)      Join Date: Jul 2009       08-25-2011, 5:41 AM Reply
If it's washed at 85, throw more weight at it and speed it up. Seth can handle 27mph
Old     (sailing216)      Join Date: Oct 2007       08-25-2011, 7:12 AM Reply
I have an Avy with storm 3. Have blade but only run half the time with it. Blade shapes and can make the wake verticle, without blade the wake still has very good pop, not mellow like different boats I ride
You can add an auto trim tab off CentCrew fairly cheap and easy (if no blade it'll be adjustible but still pointless for boarding). Does nothing really for wakeboarding, cleans up spray surfing. Avy has a great stock ballast wake, wide, but is very tempermental to weight placement (blade helps or moving people does too). Some Avys, usually a C4 non-walkthrough would wash the wake on one side. You would need to add more ballast or another battery, or about 100lbs of lead under the passenger seat to correct. Note this and make this change if you notice it on the test drive. My walkthrough has never had this problem as no seats there it's lighter already on that side.
75' back clean, stock ballast, just before the wash the slowest I can go is about 22.7mph. Speed up if you are going out farther and if we throw a 750lb sac on the floor in the middle it gets fun. Farthest we rode back is 80' at upper 24s clean.
Walkthrough saves the interior wear. I'm a surfer so don't like sacs not under the seats if riding goofy. If a big crew I have a cooler with a stock looking cushion on it for psudo wraparound seating. The other boat owners like my walkthrough, I'm ho hum about it. The boat will have most likely a 350 mag merc in it and might need a new prop for extra ballast or elevation. Whatever options it's missing, Centurion already ran the wires back to the engine which is nice to tap into (PP, Shower, Heater, Trimtab). Snap out carpet is awesome.
Old     (brycejb328)      Join Date: Aug 2009       08-25-2011, 3:52 PM Reply
^^ Great info, thanks.
So is the wake tempermental to the point where you have to be moving stuff around constantly and it changes every time someone takes a set...? or is it more.. move stuff around and get it dialed... then your good (of course someone moving over a little bit here and there is no biggy). I know I have seen on some nautiques where you cut out and the boat leans a little bit, washes out the wake and you make your cut at the wake and it still washy by the time you get to the wake
I am a little indifferent to the transom walk through... I know I LOVE the platform thing supra does when you flip up the cushion and there is just a platform to step onto.
Old     (tonyv420)      Join Date: Jul 2007       08-25-2011, 4:59 PM Reply
I love mine, only thing I'd change if I could, is get the C-4 the walkthru transom makes it a bit more difficult to sac out for surfing
Old     (gnarslayer)      Join Date: Sep 2008       08-25-2011, 5:16 PM Reply
me and my friend kurt riding an avalanche with stock ballast
80 ft at 23.5mph
Old     (bass10after)      Join Date: Feb 2010       08-26-2011, 4:20 PM Reply
that video is sick!
Old     (getssum)      Join Date: Jul 2005       08-26-2011, 4:44 PM Reply
Agreed! Great vid!
Old     (jayson_49)      Join Date: May 2007       08-26-2011, 9:08 PM Reply
Nice video! sucks that centurions get such a bad rap sometimes...but I love my Avy!
Old     (rukie)      Join Date: Jan 2006       08-27-2011, 3:38 PM Reply
I have an 05 C4, overall pretty happy with it. You will need an extra 150 lbs or so under observer seat to clean wake ( if all else is equal). As said above, 22.7 is the magic number for a clean wake at 75'. You will not get a clean wake slower than that with any rope lenght/weight combinations. Sucks for beginners, non issue if you ride 23+. IMO, the walk through is fugly/useless. Wish you were in Cali, I would get you out for a set.
Old     (brycejb328)      Join Date: Aug 2009       08-28-2011, 5:41 PM Reply
So the general consesnus.... surf wave is bomb.com and wake board wake is also nice above 23 mph with some extra weight port side.
Which for me 23 mph is "my speed" and my whole crew rides 23 or above and if there is a newb.... will... they"ll likely be riding without weight until they can feel comfortbale at 23 mph
so.. anything else I should eye up when I test this rig...? has super low hours... 190 if i remember right. The guy has owned it for 3 years and bought it with only like 70 hours.
Old     (jeff_mn)      Join Date: Jul 2009       08-29-2011, 7:09 AM Reply
how is the wake at 27mph, 5k lbs in ballast and 87.5' where I ride?
Old     (brycejb328)      Join Date: Aug 2009       08-29-2011, 7:28 AM Reply
^^ lol
Old    readyaimfire            09-09-2011, 12:14 AM Reply
Did I see a big worm in that video? Or was it a diesel? I thought I saw one of those. That trick always reminds me of Todd brendel R.I.P.
Old     (bmartin)      Join Date: Jan 2007       09-12-2011, 5:21 PM Reply
Wake is touchy but you can get it dialed in with tips mentioned, but some times it is a hassle to get everyone seated just right and stay there For speed it really depends on how much weight you have and there is only a magic speed for that particular magic weight. More weight means you got to faster to clean it up. No weight you can get a clean wake at 19MPH. With 2000+ got to moving around 24+ to clean it up.
Surf is good on starboard and great on port.
I wish I had walkthough to stern. I have owned 2 cents and have no regrets.
Old     (04avyboarder)      Join Date: May 2012       05-21-2012, 4:59 PM Reply
Wake looks pretty steep for a stock avy... Are you guys running a switchblade? Also what is the factory ballast?
Old     (xstarrider)      Join Date: Jun 2007       05-22-2012, 6:42 AM Reply
I miss the ride and the wake from my 2 Cyclones and a 2 Avys.
The wakes are right in between the old 210 and Xstar 1.0 (205v/X1) It's soupy poppy and crisp. Due to their deep V hulls they tend to be a bit sensitive to weight placement.....You just have to pay attention and mind where people sit. Like others have said if you ride with a smaller crew you will want more weight on port side to balance the boat. The Avy was by far my favorite wake of all time out of all the boats I have owned including my current. WE just lost our dealership network here so I had to jump ship otherwise I would still own one for sure. Great wakes
As far as the walk thru, some people love them some people hate them. Most who love the walk thru are beginner to intermediate riders that ride stock or just a bit over stock weight. Guys dropping extra sacs as well as big surfers will want the non walk thru to hide ballast. On a side note before you think you will be dropping 4 k in that boat in ballast take pull stock with 350-450 in the nose at 23mph. IT will surprise you. The any stock with that extra weight in the nose not far off from my XStar 1.0 with 2500lbs in it. ITs meaty
