Old     (tonyv420)      Join Date: Jul 2007       06-08-2011, 1:34 PM Reply
Does any one know if these will fit my boat trailer? trailer is a 2004 VM. they are 5 lug wheels. Thought they would look a bit better then the stock steelies on my boat trailer.
Old     (wotan)      Join Date: Jul 2008       06-08-2011, 2:48 PM Reply
Looks like a scion uses a 5x110mm bolt pattern. I don't think any wakeboat trailer would use anything that light (but I could be wrong.)
More importantly -- that car probably weighs 3200lbs. And you'd be putting roughly double that weight on those wheels? Doesn't seem like a good idea.
Old     (polarbill)      Join Date: Jun 2003       06-08-2011, 2:48 PM Reply
The offset and backspacing is probably completely off as well.
Old     (gwnkids)      Join Date: Nov 2003       06-08-2011, 4:44 PM Reply
Ford Ranger rims fit perfectly, just painted them black and look hot for $10 each from the salvage yard
Most trailers are 5 x 4.5
Old     (lakesurfer)      Join Date: Jul 2009       06-08-2011, 8:44 PM Reply
I have an 08 VM trailer. Her is what VM told me
Wheel: 14x6
Offset: 0
bolt pattern: 5 on 4 ½
Tire: 20575D14C
Rear Space: 3.5”
Weight: 1,870
Pilot Hole: 3.3
66X9 – fenders
Note: They said I could basically use most wheels that would work for an 08 Ford Ranger
Old     (hatepain)      Join Date: Aug 2006       06-09-2011, 12:14 PM Reply
Yep, when I was searching out rims online I would just punch in that I had a 2wd Ranger to determine what would fit.
Old     (spridle)      Join Date: Sep 2009       06-12-2011, 5:32 PM Reply
The metric crossover for 5x4 1/2 is 5x 114.3 which is most fwd import cars. Camry, Maxima, Altima, Celica, Probe. You can get wheels from a Ranger, 2wd Toyota , or Chrysler RWD cars. Newer Mustang, 300, Magnum. That's a short list.
Old     (rio_sanger)      Join Date: Apr 2007       06-12-2011, 6:12 PM Reply
Even if the Scion wheels fit, I would be more concerned about the load rating of the Scion tires...
