Old     (mastercraft1995)      Join Date: Nov 2002       11-30-2010, 11:14 AM Reply
What is the largest tire size you can have on a 1994 Toyota 4x4 with no lift? We will get either 15 or 16 inch rims for the truck if that matters.
Thanks
Old     (jarrod)      Join Date: May 2003       11-30-2010, 12:17 PM Reply
I would try a Landcruiser, T100, or Tacoma forum. Probably find the answer much faster
Old     (magic)      Join Date: Mar 2002       11-30-2010, 2:29 PM Reply
I had a '92 4x4. Put a set of 31" BF Goodrich Mud Terrain's on no problem with fit. Killed the mpg and what performance there was. I had the I4 motor with intake work, full exhaust (header, pipes, bigger muffler, bigger cat...)
Old     (guido)      Join Date: Jul 2002       11-30-2010, 6:06 PM Reply
31's are the factory "larger" size... A lot of it will have to do with wheel offset, etc. I stuck with the stockers on my '91 4-Runner because it's such a pig. If I were to re-gear I might consider doing something else, but it's slow enough as is.
Old     (fatsac)      Join Date: Jun 2004       12-01-2010, 12:30 PM Reply
265/75/16 should fit with 4.5" backspace. I could be wrong ...Maybe a little fender trimming but not much.
