Old     (gotwake133)      Join Date: May 2010       10-27-2010, 6:40 PM Reply
So I have been trying to remove my back seat in my 2001 pro air. I cannot get it to come out, I get it loose but it seems like there is a latch or something holding it in? Does anyone know how to get this seat out? Just the rear bench seat.
Old     (alans)      Join Date: Aug 2005       10-27-2010, 7:18 PM Reply
If I remember correctly, you need to lift out and up.
Old     (nautique830)      Join Date: Jul 2010       10-27-2010, 8:28 PM Reply
There is a latch on either side of the bench seat. should be able to easily pull forward. removing the engine cover will help work it out easier.
Old     (gotwake133)      Join Date: May 2010       10-28-2010, 7:59 AM Reply
I undid the two rubber latches on the sides, but it feels like something it hooked in the back more towards the top? Maybe ill try the up and out method again and hope for the best.
Old     (sdl39)      Join Date: Jan 2008       10-28-2010, 8:22 AM Reply
If you remove the center cushion, there should be two steel pins that you have to pull out before the bottom can be removed.
Old     (gotwake133)      Join Date: May 2010       10-28-2010, 2:54 PM Reply
I have removed the center cushion and noticed those, so I will try that, thanks.
