Old     (repo)      Join Date: Feb 2010       09-26-2010, 1:11 AM Reply
I have an 06 V215. I have just installed PP SG wake ed. What color wire going into the tacho do I splice into for the RPM pick on my PP?
Old     (jkylew95)      Join Date: Nov 2009       09-26-2010, 6:59 AM Reply
The Grey one should be your Tach...
Old     (rallyart)      Join Date: Nov 2006       09-26-2010, 10:23 PM Reply
Not the grey one at the tach on the Sanger tach guage. Grey is supposed to be the tach signal but something changes coming from the controllers on the Scorpion engine. I got fed up and ran an individual wire from the engine to the PP. In the harness at the engine, on the transmission side, there is a bullet plug labeled 'tach'. I just plugged in to that and ran the wire through the bilge.
If you figure out which wire at the tach is the signal, post it so we'll all know.
Old     (repo)      Join Date: Feb 2010       09-27-2010, 5:27 PM Reply
OK had a reply from Scott & Ron over at Sanger. Have a look under the dash about 2" along from the main harness plug (just near the hole leading up to the dash itself) is a single solid grey wire with a female flat electrical conector. That is the tacho pulse wire for your Perfect Pass tacho reading. Mines hooked up now. Works perfect.
Those guys over at Sanger are the bomb. Replyed straight away. Nice to be a member of their family? We love our Sanger
Old     (rallyart)      Join Date: Nov 2006       09-27-2010, 10:23 PM Reply
Thanks, I should have just called them back when I put mine in.
