Old     (bcrider)      Join Date: Apr 2006       07-28-2010, 12:23 PM Reply
I have 2 sets of Tower lights ( front & back facing) the front ones weren't working so I started checking everything.
Ground is good to relay
relay is switching, toggle switch itself is fine
all connections are solid
Ground from switch is good
cable from switch to thru hull is fine and attached
The only thing I have left to check is that maybe the cable within the tower has a warn spot that is arching to the tower itself causing the fuse to blow or the connection from the light bar to the tower cable isn't good but that shouldn't make a difference. My only other thought is maybe the thru hull is bad. Other then that I am at a loss of what the issue could be. Both sets of lights pull power from the same place and are both grounded in the same place or are connected in line.
Any suggestions?
Old     (acurtis_ttu)      Join Date: May 2004       07-28-2010, 12:47 PM Reply
either some sort of short ( like you mentioned---wire exposed) or battery voltage is very low. Ohms law......if voltage is low, those lights will start pulling a ton of amps to produce clsoe to their output. How big is the fuse?
Do you have an amp meter?
Old     (bcrider)      Join Date: Apr 2006       07-28-2010, 1:17 PM Reply
30 amp fuse
I do have an amp meter but not the most versed in how to test.
Old     (wake_upppp)      Join Date: Nov 2003       07-28-2010, 6:35 PM Reply
Wire touching inside the tower wont ground out since the tower isnt grounded. Now a positive and a ground wire inside the tower touching each other certainly will pop the fuse. How long does the fuse last? A little while with lights on or it pops instantly when you turn them on?
Old     (bcrider)      Join Date: Apr 2006       07-29-2010, 8:49 AM Reply
Pops instantly
Old     (wake_upppp)      Join Date: Nov 2003       07-29-2010, 5:25 PM Reply
Start checking power wires from the lights back. Run a jumper wire for stretches you cant get to like through the tower. Bypass the plug and tower wiring by connecting the jumper to the fuse and then right to the light and see if it still blows.
Old     (bcrider)      Join Date: Apr 2006       07-30-2010, 9:14 AM Reply
Thanks Sparky, I ended up just recabling the tower with a new wire. The old wires seem to still be good....no exposed wire anyway. I think it was more of the splice between the tower wiring and the light bar itself. Whomever originally installed the lights used like 8 gauge wire so I had to soder the wires together as I don't have tube connectors big enough and I don't think there was enough of a connection. I stripped back the new wire and wrapped it around and sealed with shrink tubing and double checked the ground. So far all seems to be good again.
