Old     (superair502)      Join Date: Mar 2010       06-28-2010, 4:42 PM Reply
How much should I run to each 485? I really want them to crank. Baisically my question is how much can they handle from an amp? One amp that I am looking at Is 600x1 at 4ohms rms. Would that be plenty or should I go bigger, I know alot of ppl run syn 2s for each 485 which is 700x1 at 4ohms. I know the max is 600 on the speakers but I really don't know alot about audio equip.
Old     (hatepain)      Join Date: Aug 2006       06-28-2010, 6:01 PM Reply
600 would be PLENTY to them. 450 to 550 to each from a good, clean source will make you plenty happy.
Old     (hunter660)      Join Date: Aug 2007       06-28-2010, 6:29 PM Reply
I'll just be sure to do 50% more than whatever you do.
Old    mojo            06-28-2010, 7:16 PM Reply
just start with the gain off and freq around 120 and slowly go up with the gain until it distorts, then back off a hair. head unit at 80% of max vol.
Old     (hunter660)      Join Date: Aug 2007       06-28-2010, 7:18 PM Reply
120? That seems pretty high. I'm running mine at 90, but I don't have a sub that can keep up with them either.
Old     (mjb929rr)      Join Date: Mar 2010       06-28-2010, 7:25 PM Reply
I have 2-485s and run a syn 2 to each of them. Tim at Wetsounds says this is the ultimate setup and I have to agree!
Old    mojo            06-28-2010, 7:42 PM Reply
you don't have to keep it there, but in a boat's open environment you want a higher freq. than a car. same with your sub too. if it's too bright turn it back down.
Old     (david_e_m)      Join Date: Jul 2008       06-28-2010, 8:23 PM Reply
The Pro485 due to its size is one of the few tower speakers that still has decent output to contribute below 100 hz.
600 watts per Pro485 is probably safe if its clean power at that level, and if its properly tuned and if correctly used. You'll enjoy the extra reserves for musical peaks. It won't be the maximum clean power that will damage the speakers. A lot less power can be run into compression and surpass the speaker's thermal capacity. So just run your amplifer in the 'clean' zone.
David
Earmark Marine
Old     (jason_b)      Join Date: Feb 2008       06-29-2010, 8:12 AM Reply
I've had 2k watts to the WS XXX that's rated at 1k watts max. Been 2 years and still going strong, nary a hiccup. Also put 150 watts to the WS-650's that are rated at 100 watts--been 3 years with no problems. I take great care to tune them properly though and don't try to kill them. I think WS is rated pretty conservative for what they can actually tolerate if you tune them properly.
just my $.02....I don't have to replace yours if you blow them up though. lol
Old     (ryanbush11)      Join Date: May 2003       06-29-2010, 11:59 AM Reply
just ordered a 485, it will be here tomorrow and we're going to run 750RMS to it, so we'll see how it does... i also just updraded my xs-650s from 75watts rms to 150, thouse should rock also!
Old     (superair502)      Join Date: Mar 2010       06-29-2010, 2:02 PM Reply
What about 2 of these?? http://www.millionbuy.com/ligs46002.html
Old     (ryanbush11)      Join Date: May 2003       06-30-2010, 6:14 AM Reply
So in everyones opinion what will be louder, a pair of 80s with 200RMS on each one or a single 485 with 600+ RMS?
Old     (superair502)      Join Date: Mar 2010       06-30-2010, 6:33 PM Reply
??? What about those lightning audio? It's between them and a syn 4. Don't have the money for 2 syn 2s at the moment
Old     (ryanbush11)      Join Date: May 2003       06-30-2010, 6:49 PM Reply
you will be much happier with the SYN4
Old    mojo            06-30-2010, 7:07 PM Reply
well technically 1 485 will be louder simply because more watts, but not sure about db's. with the 485 you'll have 2 8's and a horn. with 80's you'll have 2 8's and 2 horns. 1 485 will look goofy sitting in the center of your tower all alone though. definitely get a syn amp.
Old     (ryanbush11)      Join Date: May 2003       07-01-2010, 6:10 AM Reply
Yeah i've already got 4 80s and 1 485, trying to decide wether to go with another pair of 80s or another 485...
