Old     (typhoon)      Join Date: Jul 2001       06-18-2010, 5:30 AM Reply
I have a perko switch all set up on two batteries already. I just put in a new stereo and am wondering about the wiring. I have the ground lead running from one of the batteries and do i just hook up the positive lead to the perko out? Also does it matter which negative lead the stereo is on?
Thank you
Old     (schmidt18)      Join Date: Nov 2001       06-18-2010, 6:07 AM Reply
I had my stereo running directly off the back of the switch with all of the amps. The ground wire will not matter IF you have your negative battery terminals bridged. If you do NOT have a wire connecting the two negative battery terminals then your stereo will not work if something happens to the other battery or, depending on your wiring, maybe not at all.
Old     (typhoon)      Join Date: Jul 2001       06-20-2010, 6:33 AM Reply
makes perfect sense.
thank you
