Old     (dgaugler)      Join Date: Mar 2010       04-14-2010, 8:45 PM Reply
Has any one ever used one of these as a ballast pump?
RULE 17A GENERAL PURPOSE WASHDOWN PUMP 3800 GPH
http://www.defender.com/product.jsp?...84272&id=84540
Seems too me like this would fill the sacks quickly.
Old     (you_da_man)      Join Date: Sep 2009       04-14-2010, 9:54 PM Reply
Jesse on the Moomba forum is about to test out his Rule 3800 pump/system he installed over the off season. He's pretty close to getting on the water I believe or maybe he has already. He bench tested the system and had good flow numbers.
Old     (scottnaz)      Join Date: Feb 2008       04-15-2010, 7:12 AM Reply
1 1/2" outlet & 15 amps, wow!
Old     (spencerwm)      Join Date: Feb 2009       04-15-2010, 11:46 AM Reply
I am interested to see how it works for Jesse. I am thinking 3 dedicated Attwood T1200 pumps would be about the same flow rate but would be cheaper when all is said and done. Maybe I will need to do a detailed comparison once his data is available. He might be onto something.
