Old     (dreamer)      Join Date: Nov 2008       03-14-2010, 3:14 PM Reply
I added to second ballast puppy to my Centurion SV230 to speed up the fill times of the enzo sac. It was wired in to the existing rocker switch (port ballast switch) with the original pump. The question is: will two pumps on the same switch cause any problems (fuse or other)?
Thanks in advance.
Old     (volzalum)      Join Date: May 2009       03-14-2010, 3:29 PM Reply
I would add a relay for the pumps and use the switch to trigger the relay.
Old     (spencerwm)      Join Date: Feb 2009       03-15-2010, 10:26 AM Reply
I agree with Dax. Those switches are probably good but less strain on the system will keep everything running longer.
Old     (adam4x4)      Join Date: Jan 2009       03-15-2010, 10:36 AM Reply
My Cen. has a relay all ready from factory. I would check and make sure yours dose.
