Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 04, 2009
Old     (dohboy)      Join Date: Aug 2007       09-24-2009, 9:40 PM Reply
Hit something in the delta last weekend and slightly bent the tips of all 4 prop blades so I guess its time for a new one. I am going to add the fly high setup so I figure Ill be running about 2000lbs of ballast. What Acme prop would you recommend?
Old    ejojprop            09-25-2009, 3:30 AM Reply
What was the size of the prop that was crashed?
Old     (boarditup)      Join Date: Jan 2004       09-25-2009, 4:42 AM Reply
Acme 1479 is my recommendation after testing several props.
Old    ejojprop            09-25-2009, 5:01 AM Reply
We offer the 14.75 X 15.5 - 14.25 X 14.5 or 14.25 X 14. These props tested best at the MC factory under various ballast loads.
Old     (jaybee)      Join Date: Aug 2007       09-25-2009, 6:14 AM Reply
^^^^^ How do you know which ones suit your needs the best? I have just put a fly high kit in my boat and will eventually upgrade the prop and am curious how I would decide which one out of the 3 I should use.
Old     (jpuckett)      Join Date: Apr 2005       09-25-2009, 6:34 AM Reply
Call the guys at ACME and they can help you.
http://www.acmemarine.com/
888-661-ACME
They will take all the guess work out of your decision.
Old    ejojprop            09-25-2009, 7:50 AM Reply
Jayebee - Give me a call and I can help with the choice - Eric @ OJ PROPS 800-359-9730
Old     (auwakeboarder)      Join Date: Dec 2003       09-26-2009, 11:45 AM Reply
I have a 2006 X-2 w/MCX and typically run with quite a few people in the boat, often times with the Fly-High kit full. I contacted Eric @ OJ and he recommended the 14.75 x 15.5 XMP Edge. After about 30 hours with the new prop I would HIGHLY RECOMMEND this upgrade! The boat pulls much harder out of the hole and through mid range. The boat only lost about 1mph top end. Contact Eric @ ejojprop@aol.com he is great to work with.
Old     (witness140)      Join Date: Dec 2008       09-27-2009, 5:55 PM Reply
What size is the stock prop on the 08-09 X2?
Old    ejojprop            09-30-2009, 3:39 AM Reply
With the MCX it would have been our 14.25 X 14.5.
Old     (witness140)      Join Date: Dec 2008       09-30-2009, 5:52 AM Reply
On an 09' Eric?
Old    ejojprop            09-30-2009, 6:52 AM Reply
14.75 X 15.5
Old     (skibum69)      Join Date: Aug 2004       09-30-2009, 7:41 AM Reply
You shouldn't need a new prop if you only slightly bent the blades, unless you really want a new one. I had mine fixed for $75 including shipping back from a shop in Minneapolis. My suggestion is to get the bent one fixed as a spare if you get a new one.
Old     (dohboy)      Join Date: Aug 2007       09-30-2009, 7:54 AM Reply
Jason, yeah Im gonna get the bent one fixed and have it for a spare. I figured since Im adding the fly high kit to the boat I would need a little extra holeshot power so it was just dumb luck timing I bent the stock one. Ordered the new prop yesterday.
Old     (toneus)      Join Date: Feb 2007       09-30-2009, 5:17 PM Reply
I give Eric at Johnson two thumbs up. He's offered to help, why not take him up on it. Quality product!
Old     (coz)      Join Date: May 2008       10-02-2009, 4:39 PM Reply
Go with Eric and OJ props...you won't be sorry.
Old     (brucemac)      Join Date: Dec 2005       10-02-2009, 6:07 PM Reply
+1 for Eric. He's the man.
