Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (ajf4242)      Join Date: Aug 2008       08-28-2009, 10:07 AM Reply
I have two 400 lbs fly high sacks I took out of my supra that came with the boat. I have 750lbs bags back there now and was going to try to use one of the bags and put it in the walkway of my bow. I can't get the quick connects to come off at all. I tried to loosen by hand and then tried channel locks and they will not budge. I'm thinking of just plugging them with silicon or something if no one on here has any ideas on how to get them to loosen. Thanks.
Old     (nschimm)      Join Date: Jun 2009       08-28-2009, 10:30 AM Reply
Lubrication
Old     (hillbilly)      Join Date: Aug 2002       08-28-2009, 10:44 AM Reply
I used a blow dryer around the fitting. Heat it up for a couple minutes then hold the bag and twist off the fitting with channel locks. I tried to tighten then loosen mine and it popped the glue loose.
Old     (thesack)      Join Date: Mar 2008       08-28-2009, 12:39 PM Reply
I had the same problem with mine. One bag i still can't get the disconnect fittings off of. But the other i heated them up and hit them with a hammer around the fitting base and end which broke the glue loose, then used channel locks and they unscrewed with ease.
Old    pdxWAKE.com            08-28-2009, 1:15 PM Reply
Ditto... heat them up with a hair dryer or heat gun and be aggressive and you will get it... I tried and tried and it finally worked....
