Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (ajf4242)      Join Date: Aug 2008       08-10-2009, 8:23 PM Reply
I have an 08 supra 22v sunsport. I was just curious if anyone knew the standard prop that comes with the boat, like what size it is? I was suppose to have the upgraded wakeboard prop and didn't know if the 13.5 x 17.5 is the upgraded prop? I run around 1700lbs of ballast in the boat and was also curious what prop I should get and how much they would cost? Thanks.
Old     (fman)      Join Date: Nov 2008       08-10-2009, 9:01 PM Reply
If you look on your paperwork when you bought the boat it should say CNC Wakeboard Prop. Not sure about the pitch dimensions.
Old     (midwest_riders)      Join Date: Sep 2004       08-10-2009, 9:13 PM Reply
The wakeboard prop is 14 x 14.25
Old     (nauty)      Join Date: Feb 2004       08-11-2009, 7:12 AM Reply
^^^ Yep, 13.5x17.5 is the stock prop. You want the 14x14.25
Old     (ajf4242)      Join Date: Aug 2008       08-11-2009, 11:53 AM Reply
That's what I figured. I remember someone posting to check your prop and make sure they changed the prop to what is on the paperwork and I just always assumed the cnc wakeboard prop was on there. Now I realize why sometimes its been getting on a plane slow. Sucks that I just found this out after almost 2 summers of running this prop. Thanks guys.
Old     (absoluteboarder)      Join Date: Aug 2002       08-11-2009, 12:52 PM Reply
yeah that boat should come up like its empty with that weight.....with the cnc
Old     (ricabernathy)      Join Date: Jun 2009       08-11-2009, 12:56 PM Reply
do the launch series come with the wakeboarding prop? I havent measured mine...
Old     (acurtis_ttu)      Join Date: May 2004       08-11-2009, 1:06 PM Reply
^^ It's always an upgrade as far as I know...a very cheap one at that ( less than $100 usually)
Old     (ricabernathy)      Join Date: Jun 2009       08-11-2009, 2:33 PM Reply
damn bet mine isnt then..
Old     (fman)      Join Date: Nov 2008       08-11-2009, 8:27 PM Reply
The wakeboard prop is a definite must, once you have it on there you will never go back.
Old     (formfunction)      Join Date: Jun 2008       08-11-2009, 9:17 PM Reply
Its a wakeboarding boat,you would think the 14x14.25 would be the standard prop.
Old     (lancesaville)      Join Date: May 2009       08-11-2009, 10:03 PM Reply
Depends on the dealer, for example, my dealer only orders moomba and supra v-drives with the wakeboard prop. I figure a lot of dealers prob do the same when ordering boats for showroom/lot.
good god - had to add - BROCK YOUR CADDY IS BAD-ASS haha.
(Message edited by lancesaville on August 11, 2009)
Old     (ricabernathy)      Join Date: Jun 2009       08-12-2009, 6:29 AM Reply
well I got mine from the same dealer that u did Lance.. So maybe it is, Ill check tomorrow... and yes Brock VERY nice caddy!!
