Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 03, 2009
Old     (jaka)      Join Date: Mar 2007       05-22-2009, 4:35 AM Reply
Hy, i just have a question. It says in the LF manual, that if you set the inside angle and the outside angle of the boot the same,there should be no offset! But if i do that, the boot is slightly more on the toe side edge. So should i offset them back a little, or is that the actual center?
Old     (wkbrdr)      Join Date: Jan 2006       05-22-2009, 5:01 AM Reply
do whatever you want...i didn't know bindings came with instructions or that people would even read them?!
Old     (absoluteboarder)      Join Date: Aug 2002       05-22-2009, 8:41 AM Reply
it might appear as if they are slightly more to the toeside edge, but most peoples toes dont go to the end of the binding. So your foot is probably centered if you look where your toes actually are.
