Old     (priszkid)      Join Date: Aug 2007       04-30-2009, 8:12 PM Reply
hey guys- I'm kinda stumped. I've been having light issues for the last year and can't seem to find it. I've recently refinished my trailer, I would like to change out the lighting to led's. Can you point me in a good direction and pass on any wiring/installing advice? thanks in advance!
Old     (my_malibu)      Join Date: Feb 2008       04-30-2009, 8:48 PM Reply
west marine has cheap led kits
as for wiring depends on if you have maker lights or not
I would run a new wiring
buy some wire hangers with the rubber inserts to mount the wires around the trailer or use the stock ones
first check all the old grounds 80% of the time redoing the ground will fix the problem
or you have a break in the wire that is shorting out
Old     (mhunter)      Join Date: Mar 2008       04-30-2009, 8:59 PM Reply
I bought mine from e trailer.
Old     (newty)      Join Date: May 2005       05-01-2009, 7:49 AM Reply
Look for a semi truck repair place. They usually have a huge selection of LED lights. I replaced all the lights on my old trailer for under $80 and they were really high quality lights.
Chrome bezel's, new gaskets, good hardware.
Also buy a good trailer wire kit from an auto parts store. they usually have good step-by-step instructions. Should be fairly simple.
(Message edited by newty on May 01, 2009)
Old     (wotan)      Join Date: Jul 2008       05-01-2009, 8:45 AM Reply
I second truck stops.... I was able to find sealed LEDs for way cheaper than anywhere online.
