The stretchy ski rope is not for reducing line tension when jumping or spinning. The idea behind that is for folks that frequently land with their arms straight, they will develop a pain similar to tennis elbow. The idea of the stretch section is that this will eliminate the strain caused by straight armed landings with a rope that has zero stretch. Basically you need to do what Nick said, to max pop and decrease tension you really need to load and release. To make it extra cool, come in on a stronger edge than normal wake to wake, really give it some edge. As you approach flatten off and make sure your feet are under you to max your pop and as you ride up the wake really emphasize the kick off the top. This will make you go big so have fun with it!
