Old     (mike8343)      Join Date: Jun 2008       03-31-2009, 7:56 PM Reply
I just got a fusion 6 light bar for my tower and it didnt come with a wiring schematic. Called the 800 number and they're out of business, they have a company liquidating their stuff. Want too hook it up an extra aux switch thats already there on my malibu. It has a red, a black and a white wire pre wired up, not sure which is the relay. Any help?
Old     (jonyb)      Join Date: Nov 2008       03-31-2009, 8:12 PM Reply
I just bought one too, not even 5 minutes ago.
I've been in car audio and accesories for about 16 years now, and I"m gonna take a wild guess as to what those are. Take it or leave it.
Red: 12V constant
Black: Ground
White: Signal from the switch.
Side note, I read somewhere that you had the option to switch on certain lights separately... You know anything about that?
Old     (jonyb)      Join Date: Nov 2008       03-31-2009, 8:13 PM Reply
Ability to configure forward or back light configuration which can be controlled by separate switches
http://www.fusionwake.com/light_bars.php
Old     (mike8343)      Join Date: Jun 2008       03-31-2009, 9:45 PM Reply
check this out http://www.monstertower.com/Portals/27/MonsterTowerLightBarManual.pdf
Old     (jonyb)      Join Date: Nov 2008       03-31-2009, 10:05 PM Reply
So the bar doesn't have a relay in it already?
Probably go by that diagram then. 1 way to find out is to ground the black wire, then put 12V to the red to see if only a few lights come on, then power the white wire to see if the other lights come on. If that's the case, wire a relay by those diagrams.
Old     (acurtis_ttu)      Join Date: May 2004       04-01-2009, 7:06 AM Reply
you MUST use a relay when wiring those lights into your dash switch.
Less than $5 at any auto parts store.
