Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 15, 2009
Old     (bwillx2)      Join Date: May 2007       01-14-2009, 8:28 AM Reply
Can someone tell me where all the drain plugs are on this motor to get the water out? I have it in a garage with a heater but its suppose to get really cold later this week and not wanting to take any chances!
Old     (showtime)      Join Date: Nov 2005       01-14-2009, 8:31 AM Reply
it it's enclosed, especially w/ a heater you have nothing to worry about...
Old     (ponte_06_x2)      Join Date: Jan 2006       01-14-2009, 8:36 AM Reply
just lay a couple of blankets on the motor, if will make you feel better, but what tickle said is true.
Old     (bwillx2)      Join Date: May 2007       01-14-2009, 8:55 AM Reply
I just have a little wal-mart heater under the boat, will that still be good enough? Suppose to get down in the single digits and not get above freezing for a few days!
Old     (lovin_the_wake)      Join Date: Jul 2007       01-14-2009, 8:58 AM Reply
You should be fine just put an outdoor Thermometer in your garage and keep an eye on it
Old     (polarbill)      Join Date: Jun 2003       01-14-2009, 9:12 AM Reply
You boat should be fine but on the chevy blocks there should be a drain plug on either side of the lower block. You should also pull out the plugs on the end of the Exhaust manifolds. They are usually real easy to get to and use a 3/4" drive. Also there is a small plug on the transmission fluid cooler. If you have the tools it should take you less than a half hour to remove all 5 plugs.
Old     (bwillx2)      Join Date: May 2007       01-14-2009, 9:16 AM Reply
are there just 5 plugs and thats all?
Old     (insuranceman)      Join Date: Jun 2005       01-14-2009, 9:25 AM Reply
brandon, as brett said you have 2 drain plugs on the exhaust. one should have a knock sensor on it.
in re: to the exhaust manifold you should have two hoses that go together. just unscrew those two. also as brett said, don't forget the transmission cooler and your good to go.
Old     (bwillx2)      Join Date: May 2007       01-14-2009, 9:31 AM Reply
thanks for the help!
Old     (wakex2wake)      Join Date: Apr 2008       01-14-2009, 9:40 AM Reply
www.mastercraft.com/teamtalk
Old     (mike2001)      Join Date: Feb 2008       01-14-2009, 9:55 AM Reply
As a test, put a bucket of water in the garage by a colder area and see if that ever freezes, then you'll know if the boat will be ok.
Old     (bill_airjunky)      Join Date: Apr 2002       01-14-2009, 9:56 AM Reply
I doubt that a heater under the boat will do a damn thing. Put a shop light with a 75-100 watt bulb in it in the engine compartment..... or a couple of them. Then close the engine cover & block the vents with a towel so the heat can't escape.
If your going to pull hoses & plugs, then you should also pull the heater hoses & maybe blow thru them to get all the water out. The core is probably up under the dash so any heat in the engine compartment isn't going to do it any good.
