Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 07, 2008
Old     (yo123)      Join Date: May 2006       10-30-2008, 10:52 AM Reply
I currently ride a 125 LF fish. Looking to get the new ibex but not sure what size to get. Thinking about a 134. Any suggestions thanks for your help
Old     (cavlxenvy)      Join Date: Aug 2007       10-30-2008, 11:34 AM Reply
Sounds like you are around 140lbs.
Old     (yo123)      Join Date: May 2006       10-30-2008, 5:21 PM Reply
no am 5'10" 165 pounds
Old     (wakebordr11)      Join Date: May 2001       10-30-2008, 5:23 PM Reply
probably need a 139 then... or whatever the next size up from 134 is... I would even go 143 but it depends on you
Old     (gunnertom4593)      Join Date: Sep 2008       10-30-2008, 5:24 PM Reply
well based on size i would say the 138 (or 139 whichever that size is), but if youre used to using a 125 fish going to a 138 would be a big jump. I recommend the 134 for short term, but in the long run a 138 would help you more.
take your pick
Old     (hunterw)      Join Date: Mar 2008       10-30-2008, 5:49 PM Reply
i am 5'9 170 pounds and ride the 139 all the way out which i think is a 24 inch stance so you should def. be fine with a 39. good luck with the board i love mine.
Old     (chikara22)      Join Date: Oct 2006       10-30-2008, 7:07 PM Reply
i weigh 165 and am 5'8" and ride the 130 as well
Old     (dlwsrider)      Join Date: Apr 2007       10-30-2008, 7:34 PM Reply
139 is definantly the right size for you. It's a sick board, you'll Love it!
Old     (sheehan)      Join Date: Mar 2008       10-31-2008, 6:07 AM Reply
Either im losing it or someone else asked this same question this week about the same board who is also 5'10" and weighs 165 pounds
Go with the 139, I went with the 134 and although I love the board I wish I would have went with the 139. I'm also 5'10" and weigh 165
Old     (tom_paz)      Join Date: Jan 2003       10-31-2008, 7:00 AM Reply
go 144 you'll be glad you did, bigger boards are where its at.
Old     (ckkohl)      Join Date: Apr 2008       10-31-2008, 7:58 AM Reply
i am 5'11 and 150 pounds and i ride a 138 hyperlite era and love it
Old     (yo123)      Join Date: May 2006       10-31-2008, 8:33 AM Reply
Well i use to ride a 139 LF team. Will the ibex have a lot of pop
Old     (sheehan)      Join Date: Mar 2008       10-31-2008, 8:45 AM Reply
Yeah the ibex has a TON of pop with its insane rocker.
Old    sealyon.net            10-31-2008, 6:56 PM Reply
I demoed the ibex at expo and it is a great board. you'll like it.
Old     (player138)      Join Date: Jun 2007       11-03-2008, 9:45 PM Reply
Does anyone else find the Ronix boards run a bit small? I ride a 143 Covin and my bro rides a 137 One, and they both seem shorter than that. Go for the 144! By the way, I'm about 5'11 180lbs and I wouldn't want the 143 Covin to be any smaller.
Old    sealyon.net            11-04-2008, 9:35 AM Reply
They measure them end to end. So if you have a board that is pointed on the ends you are really getting a smaller board. My ronix rep told me that the one is about 5cm smaller than they are marked due this.
Old     (wakeworld)      Join Date: Jan 1997       11-04-2008, 9:38 AM Reply
If you really want a good sizing measure, look at the surface area. This allows you to compare size without having to worry about the shape.
