I've ridden and owned all three boards. Good comparison. The 138 Substance and Transcend have a similar snappy, pop, and a light feel. The biggest difference is the landings. The Substance landed MUCH harder in the flats for me than the Transcend. I sold the board after 3-4 rides for this reason. In my experience, both were similar in speed. I would rate them as fast. Both are narrower than the Absolute at the tip and tail, so they're a bit more responsive imo. The Substance molded fins span further towards the center of the board, so it's more locked down to the water when the board is flat and a little less forgivving. The Trans has less fin towards the center of the board, but slightly deeper fins all the way at the tail. So it feels more locked down when you're edging in tail heavy. If you get a Platinum, you get two sets of fin extensions so that you can customize all four edges. When the board hits the water in the flats, it maintains it's speed and makes for a smooth landing. The Transcend is as good as a wakeboard gets for me.
