It had that variable edge on it, and it spins super fast,... to my knowledge, its short, low swing wieght. I say all this but its all speculation, never got a chance to ride it but I really want to!
2007 Liquid Force Fish 129 Length: 129.50 cm/50.98 in.
Mid width: 45.21 cm/17.80 in.
Tip width: N/A
Surface Area: N/A
Weight: N/A
Rocker: 5.84 cm/2.30 in.
Rocker type: Continuous hybrid
MSRP: $299.99 USD
Skill level: Intermediate/Advanced
Fin configuration: Four on each end. Two Fish 0.9" center fins and two molded-in side fins.
Weight range: 130 lbs. to 200 lbs.
Stance width range: 46.99 cm/18.50 in. to 62.23 cm/24.50 in.
Construction: Aercore aerated Polyurethane core
Company website: LiquidForce.com
Company comments: Unique versatility…its shape is guaranteed to bring a smile to your face. Where it really shines is the ability to turn in tight spaces. Whether cranking into the wake, leaving the wake, or in the air, the short yet wide profile rotates like no other. If you’re learning new tricks and spins, crave powerful turns, or simply need a wide board, the Fish can shred like no other. Throwing buckets!
Performance “Full” Shape - Down Size 10cm-Short and wide. Surface area focused in the middle of the board for un-paralleled pop, minimal swing weight, easy to maneuver.
Spiral “V” Double Concave Hull-Not the standard “V” Hull. The “V” shaped hull spirals or turns down progressively towards the tail. Helps initiate turns and generates turning power. Softens landings by breaking the water at first contact. Feel the difference.
“C-4” Fin Setup-Four canted fins angled for effectiveness and placed for precision. Fast, loose, and have the holding power to carve like mad.
Lifted Variable Edge-There’s no catch - Lifted and soft in the middle - Forgiving when neutral, spins faster off the wake, lands still spinning - Sharpens as it nears the tail - Locks and holds edge into the water when weight is transferred into the edging position - Clean and catch free sliding.
Classic Rocker-Smooth, easy going rocker you’ve grown to love. The original fast approach simply feels good at any level and is appreciated by all.
(Message edited by hawk7 on May 13, 2008)
