Old     (trickyboarder08)      Join Date: Jul 2005       05-05-2008, 9:29 AM Reply
For my graduation present to myself I am planning on buying perfect pass for my boat. (1982 Ski Nautique) We ride with only 500 pounds of additional weight and I do have a acme 542 prop. So I have seen the perfect pass prices and the wakeboard pro is $1,099 and that seems pretty high, does anyone else sell it cheaper? Also, the perfect pass cruise is only 675, so would it be ok for me to get the cruise if I don't have a huge amount of weight in the boat? Will it hold speed good.
Old     (ldr)      Join Date: Nov 2002       05-05-2008, 12:28 PM Reply
Check this thread
http://www.wakeworld.com/MB/Discus/messages/3183/573272.html?1209348548
Old     (trickyboarder08)      Join Date: Jul 2005       05-05-2008, 12:35 PM Reply
thanks, i'll have to check into that. Did you get everything that you needed for under $800 when you bought it?
Old     (ldr)      Join Date: Nov 2002       05-05-2008, 12:45 PM Reply
I actually found a brand new system for under $700. But I checked with my friend at a dealership and he said that what i was planning on doing should work.
By the way, The install is super easy. It's one of those things that took about 3 hours just because i was double and triple checking everything. If i had to do it again, i could probably do it in under an hour.
Old     (trickyboarder08)      Join Date: Jul 2005       05-05-2008, 1:07 PM Reply
ok, i'm fixing to call up a perfect pass sales rep. and i'll see what I can do.
Old     (tigerules)      Join Date: Mar 2008       05-05-2008, 1:31 PM Reply
Go to a Nautique (Correct Craft) dealer and get Zero Off instead!!
http://www.zerogps.com/
http://www.planetnautique.com/index.php?name=PNphpBB2&file=viewtopic&p=84948
Old     (brucemac)      Join Date: Dec 2005       05-05-2008, 1:44 PM Reply
isn't zero off for throttle by wire only?
Old     (tigerules)      Join Date: Mar 2008       05-05-2008, 2:44 PM Reply
Not sure, maybe... I am in the process of upgrading from PP to ZO and was amazed at the difference between the two.
Old     (rallyart)      Join Date: Nov 2006       05-05-2008, 2:55 PM Reply
Zero Off does not work on any boat with a mechanical throttle. It also needs to use some of the other engine management functions.
I think OnlyInboards sells PP for good prices.
Old     (brucemac)      Join Date: Dec 2005       05-05-2008, 3:13 PM Reply
yeah, that's what I thought Art
Old     (bremsen)      Join Date: Aug 2005       05-05-2008, 4:38 PM Reply
Bought mine from OnlyInboards. Small discount (PP must have a ironclad MAP policy), but they do 2-day air it to you for free.
