Old     (ord27)      Join Date: Oct 2005       04-30-2008, 7:34 AM Reply
need some help guys
I have 2 reversible Jabsco pumps in a manifold
I replaced the impellers with the yellow impellers
I found that 1 of the original impellers had a fin missing
I assume it's stuck in the pvc manifold somewhere
the other pump works fine
the one that had the missing fin (now with a new yellow impeller) took a while to prime and doesn't have much push or pull
I haven't opened it all back up yet.....
that pump makes alot more noise than the other one...
could the trouble be the impeller is backwards? or would you guys tear into the pvc and look for the missing fin?...that would be a major pain the the arse
Old     (trace)      Join Date: Feb 2002       04-30-2008, 9:12 AM Reply
The pump housing might be scored. I bet the impeller fin is in a sack somewhere.
The impeller fins will right themselves when you first turn it on. I've never understood the concerns with putting them in "backwards".
Old     (ord27)      Join Date: Oct 2005       04-30-2008, 10:38 AM Reply
that's what I thought....about the backwards.....just thought I'd make sure
the thing just doesn't work well anymore
Old     (05mobiuslsv)      Join Date: Apr 2006       04-30-2008, 10:43 AM Reply
Cliff where did you get the new yellow impeller?
Old     (ord27)      Join Date: Oct 2005       04-30-2008, 11:22 AM Reply
about a month ago
from Texas Mastercraft
Old     (ord27)      Join Date: Oct 2005       04-30-2008, 6:02 PM Reply
I opened the pump and the new impeller looks good
but, there was 2 webworm cocoons around the shaft
I hate those things
perhaps it will run better now that I have cleaned it out
trace, what if the housing is scored?
time for a new pump?
can you sleeve them?
(Message edited by ord27 on April 30, 2008)
Old     (trace)      Join Date: Feb 2002       04-30-2008, 6:15 PM Reply
Sounds like it's not scored. It would be pretty obvious when you opened it. The impeller would probably be a little shredded on the edges of the vanes, too. I don't know if Jabscos are rebuildable or not.
If it doesn't get better, maybe look for corrosion in the electric motor? Measure the amp draw if you can.
Old     (ord27)      Join Date: Oct 2005       04-30-2008, 6:16 PM Reply
thanks
if I were to replace the pump, what reversible pump would you recommend?
Old     (trace)      Join Date: Feb 2002       04-30-2008, 6:58 PM Reply
Jabsco makes a nice pump, just pricey. If you're in the engine compartment, Simer isn't an option anyway.
