Old     (ryand121)      Join Date: Feb 2007       04-11-2008, 7:05 PM Reply
How are you running the wires for the LED's? Are you going through the quick connect fitting for the speaker wires, or are you just running another set of wires for the LED's all together? Thanks for advice.
Old     (soundbox)      Join Date: Oct 2007       04-11-2008, 11:47 PM Reply
The connectors for your Wetsounds should have a total of 4 poles. 2 you are using for audio the other 2 use for your LEDS. Just make sure to double check that male and female are the same config. If for some reason you only have 2 poles you need to upgrade the male and female side to 4 poles.
This is an exploded view of your Wetsounds connector.
The connectors on the left only has 2 poles and would need to be changed to the connector on the right with the matching female end.
The alternative to this is drilling..... I would get the right connectors if you don't already have them. Tim from Wetsounds should chime in here just to confirm but this is the best way that I know of. Good Luck!!!
Old     (wetsounds1)      Join Date: Jan 2006       04-15-2008, 7:35 PM Reply
Yes, the speaker connector that comes with all our speakers is the 4 pole. 1+ and 1- are used for the speaker. You will use 2+ and 2 - for the LED's
Tim
Wet Sounds
Old     (ryand121)      Join Date: Feb 2007       04-15-2008, 7:58 PM Reply
Thanks for the info, guys. Cant wait till I pick up the X-Star and the speakers later this month...
Old     (soundbox)      Join Date: Oct 2007       04-15-2008, 10:42 PM Reply
No problem. Make sure you post up some pics when you get it picked up!
