Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2008
Old     (bwillx2)      Join Date: May 2007       04-02-2008, 2:24 PM Reply
Thinking about upgrading my interior speakers. I have the factory clarions right now. Just got 2 pro 485's installed and thought...Hell... might as well replace the interiors to, but would it make that much of a difference to replace them with some wetsounds? or something else?
Old     (wakeboardin2k4)      Join Date: Sep 2006       04-02-2008, 2:29 PM Reply
ill take your clarions if you do make the switch....free of course
Old     (midlifecrisis)      Join Date: Feb 2007       04-02-2008, 2:45 PM Reply
JL Audio gets my vote
Old     (bkoz)      Join Date: Dec 2005       04-02-2008, 3:15 PM Reply
What amp are the clarions running off of?
(Message edited by bkoz on April 02, 2008)
Old     (bwillx2)      Join Date: May 2007       04-03-2008, 6:27 AM Reply
A Directed D2205 5 Channel!
Old     (bwillx2)      Join Date: May 2007       04-03-2008, 6:39 AM Reply
Amp Specs:
Directed 5-Channel Class D Car Amplifier
Bass Remote Included
RMS Power Rating:
4 ohms: 80 watts x 4 chan. + 280 watts x 1 chan.
2 ohms: 125 watts x 4 chan. + 400 watts approx. x 1 chan.
1 ohm (subwoofer channel only): 600 watts x 1 chan.
Max power output: 2200 watts
High-Speed MOSFET switching power supply and complimentary bi-polar outputs
Thermal, DC offset, reverse polarity, short circuit, and over/under voltage protection
Programmable features controlled via ESP serial databus and Directed's Bitwriter tool
Variable high-pass filter (20-250 Hz)
Variable low-pass filter (50-500 Hz)
Subsonic filter for subwoofer channel
Switchable Line Output/Subwoofer Input
Switchable 8 dB Bass EQ
Variable input sensitivity optimizes match with different signal sources
Chrome plated wire and RCA jacks ensure maximum signal transfer
Rugged extruded two piece heatsink and cover
Unity gain pass through RCA jacks
Adjustable input sensitivity: 500mV - 8V
Output for optional cooling fan / LED lighting
Old     (evil0ne)      Join Date: Sep 2006       04-03-2008, 6:53 AM Reply
The XS650s are awesome. You'll have to make the holes bigger, they will not just drop in.
Old     (bwillx2)      Join Date: May 2007       04-03-2008, 7:00 AM Reply
evil one,
what did you fill the tweeter hole with when you took the clarions out?
