Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 10, 2003
Old     (jwat142)      Join Date: Jan 2002       02-03-2003, 6:58 PM Reply
I just got two letsgoride sacks in the mail today and the connections are different than the other sack I have. The LGR ones have female openings. The waterbed connectors fit into them, but I don't want them coming out because I have an automatic system where the sacks are always hooked up. The other sack I have actually lets you screw the waterbed connector right on to it. So, what is the best way to connect the LGR sacks to my hose? Thanks.
Old     (jwat142)      Join Date: Jan 2002       02-04-2003, 4:53 AM Reply
Anybody have any ideas?
Old    chris_hargis            02-04-2003, 6:11 AM Reply
In the interim until you figure out something permanent, can you use wire ties to hold it on?
Old     (typhoon)      Join Date: Jul 2001       02-04-2003, 6:19 AM Reply
I have the same connections. Go to the irrigation department and get a npt threaded on one side and a hose barb on the other. The best permanent attatchment.
Old     (typhoon)      Join Date: Jul 2001       02-04-2003, 6:20 AM Reply
you can also use the flow-rite if you need a quick release.
Old     (jwat142)      Join Date: Jan 2002       02-04-2003, 6:29 AM Reply
Ty,
Does the sack drain alright having a connection like that since it doesn't have anything actually going down into the sack?
Old    jmccallum            02-04-2003, 6:45 AM Reply
Mine drains pretty good! Not perfect, but I gave up caring... lol
Also If you use a self-primer it doesn't matter!
Old     (jwat142)      Join Date: Jan 2002       02-04-2003, 6:51 AM Reply
I guess it won't matter then, because I have a self priming pump. Thanks!
