Old     (gabriel63)      Join Date: Sep 2005       10-20-2007, 4:06 PM Reply
How do you tighten a talor windsheid? I just notice that the left side is loose. please help
Old     (wake_upppp)      Join Date: Nov 2003       10-20-2007, 4:10 PM Reply
usually you pull out the plastic insert that runs in the glass frame and access the screws from there...
Old     (gabriel63)      Join Date: Sep 2005       10-20-2007, 4:21 PM Reply
i dont think there is plastic on the windsheild.There is a rubber that goes around the glass.
Old     (yubasanger)      Join Date: Jul 2007       10-23-2007, 12:51 AM Reply
Just below the glass on the aluminum frame is a rubber gasket that runs the entire length of the windshield. Start in a corner and remove the rubber, behind it will be some Phillips head screws at an angle into the deck of the boat tighten these screws and reinstall the rubber gasket.
Old     (nasty530)      Join Date: Aug 2007       10-23-2007, 9:16 AM Reply
You may also want to remove the screws completely, one at a time and reinstall them with silicon on them. This will help to keep them tight, especially if you have a system that puts out some bass.
Old     (spherren)      Join Date: Aug 2005       10-23-2007, 10:44 AM Reply
Is the fame loose from the hull? If so move the screws over 1/2 inch. Drill frame and hull and start with new fiberglass..
Old     (gabriel63)      Join Date: Sep 2005       10-24-2007, 6:56 PM Reply
thanks every body i will remove the rubber and move the screws over 1/2 inch
