Old     (patrick)      Join Date: Apr 2003       10-18-2007, 9:53 AM Reply
'03 bu vlx, indmar monsoon efi engine.
Where exactly does the raw water go once it enters the boat. i.e. raw water intake -> water filter -> impeller -> ???
My boat's intake hose looks like it goes straight to the v-drive unit then out and to the impeller, but that can't be right can it??
(Message edited by patrick on October 18, 2007)
Old     (mobv)      Join Date: Jun 2002       10-18-2007, 10:04 AM Reply
That is right. The impeller sucks through the v-drive, transmission cooler (at least on my previous Indmar powered boat) and then into the impeller. From there into the engine circulation pump.
Old     (spherren)      Join Date: Aug 2005       10-18-2007, 10:04 AM Reply
I believe in from bottom intake grate, around to lower v-drive unit, raw water pump, to trans cooler to top of front of engine intake, then disperse to exhaust and engine water pump and block.
Old     (showtime)      Join Date: Nov 2005       10-18-2007, 10:35 AM Reply
george is right... it flows thru the trans cooler then to the impeller and then the eng...
Old     (patrick)      Join Date: Apr 2003       10-18-2007, 12:16 PM Reply
Good to know. Thanks for the info!
Old     (patrick)      Join Date: Apr 2003       10-19-2007, 7:32 AM Reply
One more question. If I run antifreeze through the engine, would I have to use a fat sac pump to pump it out of a bucket and into the hose or would the impeller be able to suck it out efficiently enough?
Old     (mobv)      Join Date: Jun 2002       10-19-2007, 8:14 AM Reply
The impeller can suck it from a bucket
Old     (1boarder_kevin)      Join Date: Mar 2007       10-19-2007, 10:18 AM Reply
the boat will pull a 5 gallon bucket down in less than a minute.
