07-06-2007, 7:33 PM
New prop.
07-06-2007, 7:56 PM
Without a doubt, new prop
07-06-2007, 8:33 PM
That can be fixed very easily!! Now is a good time to re-prop though if you were going to do it. Check out this old article... Prop Fix Most people don't realize what is involved in fixing a prop and therefore don't really have a clue what can be fixed and what can't be. Most places want to sell you a new prop since they will make more money off you, but that can be fixed! I have seen props get fixed that were missing an entire ear...
07-06-2007, 8:34 PM
Has your strut support dealio always had glass damage around it?
07-06-2007, 8:53 PM
yeah, that was there when i got it
07-06-2007, 11:17 PM
It can be repaired.
07-07-2007, 5:58 AM
I just had mine repaired and was nearly as bad as that. Come back as good as new but had to be without the boat for a week. I'd buy a new prop and have that repaired. That way if it happens again you won't lose any water time
07-07-2007, 7:41 AM
well it happened at the perfect time, we are tied up for the next 2 weeks so I can have the down time, but I hear what your saying, thanks for all the input
07-07-2007, 9:32 AM
I hate rocks!
07-07-2007, 9:14 PM
That's a pretty easy repair. I've seen worse repaired no problem - big chunks missing, most of the blades folded down around the hub, etc.
07-08-2007, 11:13 AM
Mine was way worse and it is fixed! I defy anyone to tell the differance between the fixed one and a new one. The result is now I have a spair.
07-08-2007, 12:44 PM
Ok, I think I it should be noted that on Friday, July 06, 2007 - 8:33 pm, I made another positive post. Two previous posters clearly said he needed a new prop and then I came out and said it could easily be fixed, I think that was positive. I'm keeping track of my positive posts now and just wanted to go on the record. Thanks, Ryan PS..Good Luck with the PROP!
07-08-2007, 1:05 PM
Does anybody know if the pitch on a prop can be changed? I have a 06 X1 and with 1400lbs of ballast the stock prop (oj 13.7 x 17) is a dog. Would I be able to change the pitch to a 16?
07-08-2007, 1:13 PM
Yes, it can be done and is pretty often.
07-08-2007, 10:11 PM
this prop says 14 by 18, does that mean 14 inch diameter and 18 degree pitch? if I am going to reprop should I got with a lower pitch?
07-08-2007, 10:19 PM
I would also have your dealer or mechanic check to make sure that your drive shaft is not out of balance or bent.
07-10-2007, 7:56 PM
It takes a lot more than that to bend the drive shaft. If it doesn't vibrate after you get the prop fixed, you're fine.
07-11-2007, 7:27 AM
No prob to fix the prop!
07-11-2007, 8:55 AM
well my local prop shop said they can't do it, so I bought a new one and am goinbg to ship this one out at some point for a spare. Thanks for all the input
