I spent some time footin behind the 205 same as the 205 V same as the Xstar until they changed it to the X2 then the X1.....
(You would think the same people that named 2 different Centurions with different hulls the Lighning did that
That hull had a great curl and a good table until you got to 42 or 43 then the table was almost uncrosable. If you are just hanging out in the Curl it was a great boat.
I dont have any time behind the new Xstar but most boats will have a good curl to foot in as long as the boat will pull you the
Speed that you need you should be good to go.
