Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 12, 2006
Old    abadsvt            06-29-2006, 8:43 AM Reply
Hello all! For the last few times i have been wakeboarding since i got back into it i have been using my older boat that the speedometer doesn't work. I have been riding a 04' CWB Prodigy. I went out on a frieds Gekko boat and used his cheap wakeboard cause my feet were to big for his good board and bindings. Anyways it felt like i was going way to slow at 28mph. I kept asking him to go faster. The thing that gets me is that on my old boat i don't think i go that fast. Could it be the board? Is the prodigy a fast and good wakeboard? I am looking to buy a new board and want to fix this problem before i buy something that wont work for me. I would much rather board under 25mph so i get a bigger wake=more hang time right? Thanks Josh
Old     (acurtis_ttu)      Join Date: May 2004       06-29-2006, 9:07 AM Reply
Only sure way to know is to GPS both boats...you may have thoguht you were going slower/faster on a number of different factors.
Old     (boarder_x)      Join Date: Mar 2006       06-29-2006, 9:15 AM Reply
I would say you were not going 28. I think his speedo is out of callibration. Mine says 27.5, but I know it's not right. More like 23.5. I was adjusting it, thinking I was adjusting something else. Now, I just know that it says one thing, but it's not right.
Old     (gene3x)      Join Date: Apr 2005 Location: Dallas , TX       06-29-2006, 9:41 AM Reply
Can you imagine doing a raley at 28mph? lol
Old     (garret_s)      Join Date: Apr 2006       06-29-2006, 9:56 AM Reply
Actually Gene, there are a bunch of guys that ride that speed. I think Nunn and Lyman do, if I remember. Lyman also rides at 100ft.
Old     (gene3x)      Join Date: Apr 2005 Location: Dallas , TX       06-29-2006, 9:59 AM Reply
28mph just seems a little far fetched. I used to ride at 26 mph on my old Four Winns just so the wake would clean up. How the hell does someone ride at 100 feet? Isn't the wake just totally washed back there?
Old    sking55405            06-29-2006, 10:18 AM Reply
Randy Harris rides at 28 also.
Old     (garret_s)      Join Date: Apr 2006       06-29-2006, 10:21 AM Reply
Gene:
The simple explantion is that they don't ride a four-winns.
The complicated explantion probably includes something like 4000lbs ballast and a 23 foot V-Drive.
If you don't believe me, go pick up "Such is Life". Lyman looks like a freakin spec on the end of the rope.
Old     (gene3x)      Join Date: Apr 2005 Location: Dallas , TX       06-29-2006, 11:22 AM Reply
That can't be the reason because I now have a 24 SSV (3200lbs) and my friend has an LSV (2700lbs).... we both load ours out and the wake still washes beyond 85ft. Mine does at about 80.
Old     (big_xstar)      Join Date: Nov 2004       06-29-2006, 11:40 AM Reply
"That can't be the reason because I now have a 24 SSV (3200lbs) and my friend has an LSV (2700lbs)...."
Is that the weight of the boat alone or is that additional ballast on top of the weight of the boat. All pro riders sack out there boat usually close to 4,000 lbs on top of the weight of the boat, hence riding at 90-100 ft back and at speeds near 28 MPH.}
Old     (jeff359)      Join Date: Jun 2005       06-29-2006, 11:51 AM Reply
Believe him, some of the pros are riding at that speed and length.
Old     (md5150)      Join Date: Apr 2006       06-29-2006, 12:02 PM Reply
Gene -
Which ballast system do you have in your SSV?
Old     (gene3x)      Join Date: Apr 2005 Location: Dallas , TX       06-29-2006, 12:19 PM Reply
I upgraded to 2 850lb sacs in the rear and the Standard 1150lbs up front plus an extra small sac & weights I move around for balancing. Technically it is a little bigger than the Gravity Games Ballast.
Old    abadsvt            06-29-2006, 4:40 PM Reply
His speedometer is accurate. Could it have been my wakeboard that i was riding.
Old     (bdaddy)      Join Date: Jun 2006       06-29-2006, 5:16 PM Reply
At 100ft how far from wake to wake? No way I could make that distance.
