Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 25, 2006
Old     (ak4life)      Join Date: Nov 2003       04-19-2006, 5:37 PM Reply
Questions:
1. Which one do you think has more surface area?
2. Which one is lighter?
FISH:
Length 137.20 cm/54.02 in.
Mid width 46.70 cm/18.39 in.
Rocker 6.30 cm/2.48 in.
Rocker type Continuous hybrid
Weight range 180 lbs. and up
Stance width range 48.26 cm/19.00 in. to 63.50 cm/25.00 in.
Construction Aercore aerated Polyurethane core
TEAM:
Length 143.30 cm/56.42 in.
Mid width 43.68 cm/17.20 in.
Rocker 6.35 cm/2.50 in.
Rocker type Aggressive continuous
Weight range 165 lbs. and up
Construction Aercore aerated Polyurethane core, PBT top and bottom
thanks in advance..
Old     (thane_dogg)      Join Date: Jun 2002       04-19-2006, 5:52 PM Reply
the fish is going to have more surface area.
the weight of the two boards is going to be so close considering the team has less mass, but it does have a PBT bottom and the fish does not. PBT is heavier than the alternative.
Old     (ak4life)      Join Date: Nov 2003       04-20-2006, 12:58 PM Reply
Thanks Thane! What does PBT do anyway?
Old     (thane_dogg)      Join Date: Jun 2002       04-20-2006, 5:50 PM Reply
PBT is the shiny sheet that they put on the boards. Almost all boards have it on the top, but some have it on the top and bottom. From what I understand, it's a little more difficult to make the bottom PBT when there are molded fins. PBT is a little more durable I believe.
Old     (ak4life)      Join Date: Nov 2003       04-20-2006, 6:06 PM Reply
right on.. thanks much for the info...
Old     (shavis)      Join Date: Aug 2005       04-21-2006, 4:54 PM Reply
doesnt hype do PBT on top and bottom of their boards...because if they do that would explain why their boards feel so heavy
