The most important question is: What do your battery cables look like? It is common for boats to use a lug terminal (a terminal with a 5/16" hole in it), in which case you need to get a battery with "binding post" terminals. This generally means "Marine" or "Deep cycle" type battery. If your boat has the clamp type battery terminals then you need to get a battery that has standard top posts. It is also possible that your boat uses the batteries with side posts, which would be a drag. My '03 SAN uses the old fashion top clamps. Once you have figured out what terminal type you need then I would get the biggest battery that would fit in the space. I do recommend a deep cycle battery if you intend to run stereo equipment with the engine off.
