I've got an 04 Centurion Lightning and I'm very happy with her. I think the Lightning is the same hull as the Elite V. The Elite V will be a good wake boarding boat but to get a quality wake you'll need to get to the equivalent of the stock triple ballast. The side tanks on my Lightning are 22 gallons, that’s about 180 pounds. I don’t know how big the center tank is but I suspect it’s the same size as the side tanks, it takes about the same time to fill. I don’t have experience with other wakeboard boats so I can’t compare wakes, but I’d say that the wake with a crew of three, driver watcher and boarder, and full stock ballast the wake is really very good. I’ve been able to wake surf off the port side with stock blast and a crew of three. The wake surf wake is better of course with more ballast. Is the wake plate on the elite v fixed or does it have Bennett trim controllers on it? I find that I set the trim to 0% for most wake boarding, but have to increase the trim to 100% for go-fast speeds. It may not be necessary if you don’t have ballast tanks.
