Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2005
Old     (derrick_lenz)      Join Date: Feb 2003       07-16-2005, 6:50 PM Reply
alright i already know that the ski natique 2001 is considered the best bang for your buck but does anyone have anything good to say about other old model boats for wakeboarding? i'm looking to buy a boat this upcoming march and would like to spend around $8000. please, if you got a ski nat 2001 post pics of the wake, speed, length of rope and how much wieght your running i'd greatly appreciate it.
Old     (bear)      Join Date: Apr 2005       07-16-2005, 7:32 PM Reply
The 1995 pro star 190 is one of if not the best! it throws an awsome wake! Here are some pic of mine.
Old     (dkmode34)      Join Date: Mar 2004       07-17-2005, 7:32 PM Reply
i have ridden behing some air natiques fro like 98 or 99 that throw a ridiculously huge wake when u load it with weight
Old     (mjmurphy53711)      Join Date: Mar 2004       07-17-2005, 7:35 PM Reply
he said 8 grand not 25 grand guys......
my suggestion would be any old nautique or mastercraft....especially an old nautique excel if you can get your hands on one its a vdrive
Old     (ramhouse)      Join Date: Apr 2004       07-17-2005, 8:01 PM Reply
Early '90s MC....very dependable and best of all...NO WOOD..
Old    munson            07-17-2005, 8:17 PM Reply
Jason, thats a damn nice wake. Especially for dd. how much weight did you add for that? Cause that looks similar to x30 i rode behind last week with 1000 lbs factory ballast
Old     (bear)      Join Date: Apr 2005       07-17-2005, 9:14 PM Reply
Well, in those pics I was using the fat seat in the back. About 1200 lbs and then
about 250 - 300 lbs of lead in the bow. However, I just switched my set up
and I'm actually getting a bigger wake now with the same kind of shape. Now
I'm using 2, 600 lb sacks on the side of the engine compartment, 300 lbs up
in the bow, and another 350 lbs of lead in the back under the stock seat. I
switched up the arrangement because I had to take out the stock back seat
for the fat seat to fit and it took away some sitting area. So know with the added
weight and 1 - 2 more people on the boat the wake is even bigger and better.
Old     (derrick_lenz)      Join Date: Feb 2003       07-17-2005, 9:55 PM Reply
jason thanks forthe pics and input....
anyone ride behind a early 90's ski natique? how was the wake? pics?
Old     (ramhouse)      Join Date: Apr 2004       07-18-2005, 5:47 PM Reply
Bear,
Thanks for the low down on your weight distabution..i'm going to try it tomorrow...
Thanks again, Richard
Old     (ramhouse)      Join Date: Apr 2004       07-19-2005, 10:53 AM Reply
Bear,
What is your fule and time ratio. Today i used #431(rear),#215(on ea. side),& #300(in bow) and i went thru 15gal. in 3 hrs. using a 4 blade, thurs i will try my 3 blade..Wake was good and fat...
Old     (bear)      Join Date: Apr 2005       07-20-2005, 9:28 AM Reply
To be honest with you I have never really looked at how much gas i use with the 2 different set ups. However, with my current set up. I believe they are right about the same. We usally ride from 6am to 2 pm every sunday. Now I'm not running the whole time. So I would say in about 4-5 hours I use about 1/2 a tank of fule. It was worse with the 3 blade prop though. The 4 blade helps it get on plain faster so it doesn't use as much gas. Hope that helps.
Old     (ramhouse)      Join Date: Apr 2004       07-21-2005, 8:21 AM Reply
Bear, Where do you ride on Sundays?
I'd love to check it out. You are right about the planning issue, but i have noticed that with the 3 blade it sure is a lot easier to hold speeds. Rich
Old    dr_wakeboard            07-21-2005, 10:08 AM Reply
Jason,
That boat is a 1995? It's beautiful and it doesn't have that 'batman symbol'on it. Nice and simple and not flashy- just the way I like them. Is the tower stock, or did you buy that later?
Old     (ramhouse)      Join Date: Apr 2004       07-21-2005, 2:12 PM Reply
Batman symbol???what u mean???
Old    dr_wakeboard            07-21-2005, 2:54 PM Reply
I came across it on another post- That's what somebody was calling the logo on the side of the boat where it says the model name ex: x-star, x-2, x-5 etc.
