Old                10-16-2004, 8:37 AM Reply
i was just wondering. I live in minnesota so i only have a little time on the water before it gets ice on it. so i was wondering if you can get better on a skateboard and how to do it.
ps i just got it so im not very good on it.
Old                10-17-2004, 7:34 PM Reply
yea skateboarding helps. it helps with balance, ollies on a wakeboard, switch, and probably other stuff. snowboarding also helps with these things other boardsports liek surfing too but seeing as your in minnesota you probably won't be surfing unless its behind your boat. and how to do what?
Old                10-18-2004, 12:51 PM Reply
like "what" to do and you already answered it so thanks
Old                10-18-2004, 1:27 PM Reply
If you mean get better at skateboarding than all you have to do is go outside for hours at a time and just keep practicing till you get it, learning to ollie takes a while but once you get that than all the other tricks will come with some ease.
Old                10-18-2004, 3:21 PM Reply
thanks
Old    stoked27            10-20-2004, 4:41 PM Reply
helps a whole lot riding switch. plus i have a longboard, so i can have a wider stance more like I would have on the wakeboard. Yea, it helps quite a bit.
Old                10-20-2004, 7:30 PM Reply
alright
Old                10-21-2004, 1:08 PM Reply
yeah, skateboarding helps. In fact, I spend a lot more time skateboarding than wakeboarding. It really helped with switch, and...pretty much everything. yeah, the only difference is that there's no rope...that's kind of different, but the fundamentals are similar.
